philbert said:According to the Overclockers review of the SLK900 it says you can't use a 92mm fan on a P4?? That really sucks, I was just about set on ordering one but now I'm reconsidering....
stan03 said:
ehh? yes you can, if you read on it says you can only do that if you mount it on the retention bracket, if you mount it on the springs, then the 92 will be fine.
