I'm going to AIR cool a CPU with a new experimental heatsink/fan design that should be able to handle a 150+ watt peltier. Where can I get a good one at a good price?
Just remember if you are using a 150w peltier and your cpu is putting off 60w then the HSF has to be able to handle 210w. That seems really high. I have a 80w tec water cooled and my cpu
is -25c under full load. I had the 80w tec on a HSF and it got DAMN HOT!!! I hope it works for you...
