I'm in the market for a Socket A water cooling system. I just want the water block, 12v DC pump, and an 80mm radiator. I particularly like the Swiftech line. So where's the best place to buy this stuff online?
Always check the stickies. Right at the top of the page. The best ones would be directly from Swiftech, Danger Den, and D-tek. Then some good resellers with a mix are Cooltechnica and Criticool.
then don't forget you need some tubing - i'd suggest clearflex60 1/2" ID x 3/4" OD, and then a t-line - you need a T-fitting and a fillport cap - all of this is available @ cooltechnica.com
and then some stainless steel worm drive hose clamps from your local hardware store (1 for every barbed fitting - usually .50 to .90/ea. depending on size)
