- Feb 27, 2002
- Nashville, TN
When I order a new CPU to replace my old T-Bird that I toasted, I'm going to order a new HSF as well. No point in using the Alpha 8045 since that's what toasted it in the first place. Plus I really don't want to have to remove the motherboard again to install it.
So, what I'm trying to figure out is the best HSF to get. I'll be using a low-medium airflow fan on it. No Deltas or similar for me thanks. I'm thinking something in the 20-30 dB range, so probably around 25-30 cfm airflow.
It also needs to mount using the lugs on the side of the socket, not the mounting holes.
And oh yeah, it can't be very expensive. Preferably no more than $30 or so.
So what's going to be the best HSF to meet my expectations. I'd hoped to go watercooling, but simply can't afford it right now.
