- Jun 11, 2003
- Auckland, New Zealand
I am ready for water cooling now, and reason is i need quiet.
I am currently using 2 TT smart fans cooling my CPU, one with temp sensor on top of my thermalright and the other set on minimal spin on the side case and they are loud for me. Ofcourse I have 5 (4 come with the case and 1 80mm vantec stealth) more fans in the case adding to the noice level. But I dont want move to water cool and find it will the same noice level again!
So I have decide to go for a Swiftech 350 for pump (good for silence)and now its all up to fan selection.
Because i am using my current case, a Lian Li PC65, i can only fit a Black Ice Pro in there (i hope). Therefore i need fans that can blow some decent air but quiet as well.
I read alot of threads in regards to fans and so far I have one question which i cant seem to find.
When ppl say under volt fan can reduce the noice. Is it safe to assume the dbA and cfm will reduce in ratio with RPM? If it is I find the delta's latest 220cfm fan to be the best cfm / dbA ratio at 1500rmp in comparison with say the likes of Panaflow, Sunon, Evercool, Papst, etc
Also if I use 2 fans for push and pull on the rad, does the dbA output double? e.g. 22 dbA become 44 dbA for 2 fans?
Thanks for reading
Thanks for reading
