- Jul 7, 2002
- Sandy Creek NY
Im planning on building a new system, and the whole ram issue really has me confused. I'm planning on using an athlon XP2800 and a chaintech 7NJS Zenith mobo. I'm under the impression that I want to go with pc2700 because it operates best with the 333FSB that the cpu uses. Im also debating on getting (2) 512mb sticks or just one, or possibly (1) 512 and (1) 256. I keep hearing about "matched ram", does it make that big a difference? should I buy (2) matched sticks of 512? I'm tentatively planning on using corsair XMS pc2700 DDR 333 ram, which I can get from tiger direct for $95 dollars a stick....anyone know of something that will perform as well, if not better for cheaper? or where I can find this memory cheaper?? all your advice and help is appreciated!!!
