Best setup to get 0-10c under full load?
Treker
Old School Senior
Houston
Hey Guys,
Yeah, Trek's around again, big deal.. anyways..
Wondering what the best cooling set up would be to get said temps (0-10c or below under full load)
I have a p3700E cCO fc-pga chip (lucky me!) running alone on an abit vp6 mobo till I can afford a second one and win2k
I've been thinking of water cooling for a long time now, have a full tower case and easly could fit in a raditor in the back above the psu, a pump/tank under the drive cage, ect..
But wondering if I should make my own set up or get a kit? really the only thing I see that pays to buy a quality part is the water block.. but whats the best copper water block?
-Trek
Water cooling will only achieve your room temp, at best. Assuming your room is not in the 0-10C range, then you need a water cooled peltier system. I don't have any specific system model numbers for you.
Hoot
go to google, under search type in chip eckert chiller- that will get you to o and under, I am currently at -10 degrees using the (3) 115watt peltier chiller. at best over "normal" peltier cooling we are only talking about 100-150 mhz over the average watercooled setup, but hey, who wants average results?? ;-)
