- Nov 5, 2017
ive got the ASRock AMD 990FX Extreme9 to pair with the fx8350 an 32gb of the
Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz DDR3 CL10 DIMM - Black (HX318C10FBK2/16)
an i plan to upgrade from my cooler master nepton 280 to a Aquacomputer airplex radical 4/360, copper fins rad with a triple set of
Cougar Vortex PWM 120 Cooling CF-V12HP
1 set on the out as push an 1 double on the in side as pull so cooling shouldn't be an issue
i love asrock iv used a Fatal1ty 990FX Professional for 6 years an its run great but no more its seems to be very unstable under full 8core load an will crap out while gamein useing all 8core or rendering useing handbrake
i use to be able to do both at the same time
some high to ultra game like crysis 2 on ultra an 3 on high
while compressing video in handbrake
with these settings
constant frame rate of 24
a 2pass avg bitrate 5000 no turbopass
encode tuning set at film encoder profile high
an encoder level at 5.1
most 2plus hour films would take about an 1hour 15mins to complete but i could game at the same time
an not break 52c
while gamein not break 44c
an handbreak 48c
my idle was 27c
all above with a room temp of 68 degree
my cpu setting were at 4.5ghz at 1.3875 volts i dont remember what my other setting were at this point
but now to even stay on let alone game iv got the volts at 1.45 but it still is crap for rendering
an my idle is 32c
gamein load is 46 but not useing all 8cores
i can say it not the cpu because my sister has the same cpu an i swaped them an got the same result good on hers bad on mine
so to anyone please some advice for best possible oc to 4.5 or higher on my new board
thanks
with these settings
an not break 52c
an handbreak 48c
my idle was 27c
an my idle is 32c
thanks
