- Oct 25, 2001
Alright, comrades, here is the story:
I have a 1400 Thunderbird, but it's the old green-cored "B" Athlon with a 200mhz front side bus. It has a locked multiplier but I've used some trace tape to handily unlock it. It is on a MSI K7T Turbo mobo (KT133A chipset) with 1 512mb stick of Kingston PC133 SDRAM. I have a 8045 heat sink with a 50CFM Sunon fan for it. This machine will hopefully soon be folding full time...I will use it for nothing else. What I am wondering is this...
Since this chip will probably run with a 266mhz front side bus, should I lower the multiplier to 10.5x and raise the bus speed to 133mhz to run it at 1400/266? This is what I would do normally for all around better performance, especially on a DDR system, but since F@H relies mainly on the CPUs internal FPU performance I am thinking that clock speed should be my main concern. I could do several things:
1. Leave the multiplier at 14x(100FSB) and overclock using the front side bus.
2. Drop the multiplier to 10.5x, raise the bus speed to 133mhz (yielding 1400mhz) and then see if it goes a little higher (140mhz or so).
3. Raise the bus speed to 133mhz and overclock via the multiplier primarily and a little FSB also - i.e. 11x135 or something.
So basically I'm wondering for FOLDING ONLY, what is the best way to overclock this CPU so we can catch [H]?
