best way to clean my mouse?
If it's a ball mouse, take the ball out and wipe the dust off of it. Then blow in the place where the ball was. Make sure the two little roller things can move freely, then put the ball back in.
For an optical mouse, just blow the dust out of the place where the light comes out.
there is 2 black rollers and 1 white rollers, the white roller has crap all the way around it, it's hard to get off to, Prolly there when teh guy from work gave it to me to
Just use the flat blade of a knife and kind of 'shave' off the belt of crud on the roller. Won't take much and it might even come off in one piece.
thanks, it took a while but it works a lot better now, that stuff was hard to get off
I use tweezers to get the gunk off works pretty well.
