Best way to overclock video???
itizme
Barrie
What are the programs in use?
Are any better for ATI?
Should I add cooling before touching this one, the card is merely heat sinked
I believe for ATI that Powerstrip is the way to go.
Depending on how the heatsink is attached to that card, you might wanna remove it and drop some AS3 or your favorite thermal grease on there. Companies usually skimp in that department.
Have fan, will install
After doing a little reading I think the rage3d is the way to go so I downloaded this one, looks like alot can be done and alot more learning to do naturally.
Is there a way to monitor temp on a radeon 9000?
Maybe I should start a new thread on this one?
