- Jan 4, 2001
- Northern VA
Just glanced over an article on BGA cooling, found it informative so I'm posting the link to it:
Basically, BGA cooling is the term they use for putting a fan behind where your CPU sits. They did this by cutting the mb tray and attaching a fan. Results seem to be really good as they reported, idle temps down 7c, load temps down 7c as well. Certainly not bad.
One reason I mention this though, is I know there may be some problems with the Swiftech and the new Alpha 8054s moutning system...not really a problem, but getting the screws off I heard requires removing the mb. But, I guess cutting a hole behind the board on the mb tray would fix that minor issue.
Mike
Loading…
www.max-hdw.com
Mike
