- Mar 18, 2015
I have a small project that is browing in size the more I look into it. Here are the essentials.
I have this fan controller and dislike the color the LED lights. Blue is fine, but the red has gotta go. I thought to simply swap the red bulb for a white LED, but it was not that simple. There are not 2 LED in there. ONly 1 that shines in 2 colors depending on the position of the switch. No big deal right? Get a blue/white bi-color LED and be done right? Perhaps.
Here is where things have gotten complicated. Apparently all colors of LED require a different voltage, normally about 1.3-1.6V (quoting from memory, I hope it is near correct), while the white needs (again from memory) 3.6-ish V. What I have seen when looking for bi-color replacements is that many are the colors that share similar voltage (red/green blue/red etc). I worry that there may be some sort of voltage issue that will arise from swapping a red/blue for a blue white. The specs are similar but I am not sure if they are similar enough.
Blue/white
A red/blue. Not neccesarily the one that is already installed
Thanks in advance guys
Blue/white
