i got a 1984 model 220V comair patriot. the bearings on the fan are shot, they whine. i measured them to be 12mm wide 4mm thick and 4mm id hole. anyone know where i can buy some bearings?
it dosen't cost much so why trying to change bearing ?
if you still whant to change the bearing, check out at your nearest autoparts shop. They gonna be able to get you the bearing if they don't have it on stock.
