- Jan 20, 2006
- Westchester, NY
As i was testing stability with super pi like 10 min ago, my computer shut off abruptly. I thought to myself "dang, i guess my cpu isnt stable enough to run at 4.3 ghz." i tried to turn the computer back on, with absolutely no luck. The computer would turn on for a second and then imeeditely (like 0.0001th of a second after) turn off. I tried the connector test, and connected the green wire on the atx connector to the black wire above it. Same thing, the fans began to spin and then turned off before they even accelerated.
I'm gunna try to borrow the power supply from this comp to make sure but after that, i guess i'm gunna have to buy a new one. So, any opinions on whcih power supply to buy for general use. Preferably over 500w, cause the old one was 410w, and that obviously wasn't enough. Also, modular would be cool. My budjet is about 100$ MAX
