These are the requirements to receive -bigadv WUs:
1. 8 or more physical or logical cores.
2. 0.15 GB of ram per core dedicated to folding
3. You must have the Linux Client v6.34, or the Intel/OSX v6.34 client, available from the main download page.
4. You must have a passkey
5. You must select big WUs in config
6. Advanced Methods must be turned off in advanced configuration
7. The proper start string is -bigadv -smp -verbosity 9 (order doesn't matter) either in extra parameters of advanced configuration or in the start string. The client will default to using all detected cpu cores. You can use -smp X, where X = number of SMP threads to run. Setting this number to number of cpu cores - 1, will allow cpu cycles for GPU clients and maximize -bigadv + gpu production. Prime numbers default to the next lower non-prime number of threads (most of the time and the WU will crash if it doesn't).
8. Successfully complete 10 a3 or a5 WUs within the preferred deadline with your passkey to be eligible for the bonus. If you've folded the requisite qualifying WUs on any machine with your passkey, the QRB will be awarded on your first -bigadv WU. If you have never used a passkey, fold 10 a3 WUs, after adding the passkey, before adding the -bigadv flag.
9. To qualify and remain qualified for the QRB (Quick Return Bonus), a client must have successfully returned >80% of its work units within the preferred deadline.
10. If you're running in a VMware Player 3.0.0 VM (higher versions won't run 8 threads on an i7): you MUST edit the VMware Configuration File (.vmx) and change numvcpus from "4" to "8" and add priority.ungrabbed="idle"; You need 2200 MB of ram to run a full unix distro, 2100 MB for a light distro.
11. The -bigadv 12 WUs require 12 physical or logical cores and reporting > 2800 MB to the Assignment Server.
