Bilge Pumps
country_3030
Paris, Texas
Could you use a bilge pump out of a boat? Most can handle constant use, produce little heat, and run off of 12volts. I found one for $15 at walmart. 500gpu
skinart
Canada
I think you will find that bilge pumps dont have a long life expectany most are around 1500 hours or so, pleeze correct me if i am rong someone.
JDXNC
I'm not sure on how long they last but if its gonna be the lifeline for your PC I wouldn't comprimise safety over price... check into it first.
