- Mar 8, 2002
- Paris ,France
From reading this , i'll keep the 43a for the moment it has everything the other bios have including the cold boot pb but only with the fix option (it strangely appeared only after a month of use )so i'm running my 1,6a at "only "2378 (148 fsb) with 2/4 option (at 150 onboard sound don't work ) but i can reach 2600 with fix (not stable in P95 ) . Too bad i can't get 165fsb ,that would be perfect with 2/5 option giving 66 for AGP and 33 for PCI .
It's the RDRAM fault as it won't take more than 123x4 = 492 Mhz so 165x3= 495 is too much . Waiting for PC1066 like many of us OClocking freaks !
1,6A@2500@1,65v+ Alpha 8942 + SUNON 50CFM case temp 25°C cpu temp 44°C idle 56°C full load (p95 ) MB temp 30°C idle 35°C load
2x128 Kingston RDRAM PC800 @156x3
TH7 II+ GF 2 PRO + 2HDD Maxtor D750X 40G
Lian Li PC 69 case with 2 fans intake + 1 80mm exhaust + 1 slot fan +Enermax 365 PSU with 2 exhaust fans !
case temp 25°C
case temp 25°C
