- Jun 14, 2018
- London
Dear Engineers and technicians
I have an issue that I couldn't sort out myself, perhaps someone with more experience on this situation could give me a solution for my failure.
Here is the case: Powercolor model axrx 570 4gbd5-3dhd/oc Red Dragon does not display on post but can be detected by windows 10. Bios have been modified by an less informed person that not only flashed a new bios but flashed it on both bios position.
The card is accessible on the device manager when the computer is booted with integrate or other card. I am able to flash any new bios on it, but all previous attempt resulted to the same issue. However, some other bios just makes the windows crash when GPU-z is initialized.
I have contacted the retailer and I have been told that if bios is upgraded the warrant if voided. I have downloaded almost all available bios that can be found by searching on google. Since the warrant can't be a solution, I have removed the heatsink to investigate what memories are on this card. They are all SK Hynix, 8 chips total 4GB. The reason for this is I wasn't sure if the bright person had flashed the correct memory type to start. It could be samsung or elpida as if you flash the wrong bios it will be displayed on GPU-z with the information of the new bios despite you have other memory. this point perhaps can help people that see a type of memory on their GPU-z and insist to flash with that information.
Resume: Card installs, I have tried 5 different versions of AMD drivers. including blockchain drivers. The GPU is visible as installed on the device manager, but no display, no Fill rate Pixel or Texture and the clocks are 0 (Zero). Cables have been tested, ports and screen are all fine. Contacted Powercolor requesting the original bios for the specific serial number and model but no reply yet. I have read a number of people teaching how to flash but this isn't the issue. I can flash any bios that I have, the problem is no bios seems to make it work. I had the same problem while ago with a Sapphire R9 270x, downloaded more than 10 bios that apparently were the same to finally find only one that made the card post. On this case I believe that only the original hynix memory bios without elpida or other memory mixed would work.
If someone have this bios around please let me know. I could be wrong and the problem is something else, but so far I haven't seen any case like this before and I would appreciate any expertise though on this issue.
Kind regards,
ITM
Kind regards,
ITM
