Bios F7 released for K8NS Ultra 939
Rattle
Home... again
http://www.giga-byte.com/Motherboard/Support/BIOS/BIOS_GA-K8NS Ultra-939.htm
I may flash it tonight just to see if anything new is there aside from dual core support, like a 183 memory divider or more vdimm perhaps?
Ok I went and flashed to F7 just to see if there was anything of value.
Most of the changes were made in the Advanced Chipset Features section of the bios.
There is new memory dividers it seems, on F6 we had a choice of 100, 133, 166, 200, now we also have 216, 233 ,250 oddly enough.
There is a new line under memclock called Memclock index value which wasnt there before, where these cahnges can actually be made.
They have added a function called:
Bottom Of 32 bit [31:24] IO
I have no idea what that is :shrug:
And they added
Mem Remap (4GRam Support)
Another addition
Read Preamble Value
Another addition
Async Latancy Value
Missing from the advanced chipset features menu is the
Refresh Period (TREF) settings.
which was present in the F6 bios....
No added vdimm for you guys that were wondering.
Only other thing I see different aside from them renaming features that were already there in 3 or 4 instances was they added
USB memory value set to shadow by default or can be changed to 640K base memory.
I found myself looking for settings I couldn't find because gigabyte decided to rename them haha.
I had no probs flashing and booting into windows after, only thing I see now is when i try to open my NVmonitor it gives an error saying no bios support now ???
I cannot overclock with this bios because I am waiting on some ram, I'm actually using 512 corsair at the moment while I wait for me new OCZ 4200's
I will have overclocking results with the bios soon as I get them.
Well.. All i can say is.. It wont oc with this F7 BIOS.
All i can get if i change any cpu/fsb/htt settings, is automatic BIOS reset after boot.. Same thing if change memory settings "too much"..
Did try mem 216 divider with default cpu settings (my mem can do that, and cpu is venice), but after i save this settings and boot (boot from memtest floppy), it say my memory was fsb100MHz (DDR 200MHz).. :eh?:
Dont know if it's just becourse i have only single core cpu.
So, if you dont have x2 cpu, i think this BIOS is NO-GO!!!
Hope it works with dualcore cpus. :shrug:
Yeah I got the impression it may just be a dual core cpu bios.
The site said it was just for dual core cpu support, maybe thats all it will support :shrug:
I flashed back to F6 anyway.
I want my RAM !
Nice find Bro :D
I'll update to it after the LAN party this weekend and see if i can get any new results
Cool man,
My ram is in tampa, within an hour of me, but i have to wait till monday...
...looking up fedex's number in tampa :p
buttonmash said:
How does F7 compare to F8that Xinot flashed to?
Any increase in VDimm? Any changes/unchanges from F7?
It looks like same as F7, but F8 really works better for me.
No more vdimm etc., but nice memory settings with both bioses. I like this "auto" settings when troubleshooting some memory modules.
One little bug was, that i changed bios settings too much, and it didn't boot up, but it did reset the bios and booted up after that (bios settings was defaults again).. This was with F8 bios. F7 did this all the time without any good reason.
ps.sorry my bad english.. :rolleyes:
there's an F8 for our board ???
holy crap I went and looked...
is it much different from F7??
I seem to be limited on this board to 285HTT
anyone else ?
anyone else ?
Well, i'm running this at 8x325 fully stable.. Stock voltages to chipset/htt.
Had to boot up with 295, and again with 300. After this i went up to 325, and it booted up fine.. Haven't try any higher yet..
