I just tried to flash my Kt7-raid mobo. and it froze up on me so after 1hr. i shut comp. down and restarted and nothing.So i ordered a new chip from BadFlash.com but i was wondering if i could somehow salvage my old bios?
There is a handy little device out there called BIOS Savior that plugs in between the motherboardand the BIOS chip. It stores the BIOS on it in case there is a corruption of the BIOS. It costs about $20 and can be found at http://direct.mwave.com/mwave/bios.html.
When you said ou re-started...do you mean with the bios boot disk, or without. Will it boot to the disk? You should be able to re-flash it. I have saved a few pcs that way. Hope you get in!
The comp. doesn't even boot.I tried with just the hard drive&videocard hooked up,but it doesn't even seek floppy when i power up.Hopefully all will be fine when the new bios chip is installed.THANKS to everyone for your ideas.
if you know someone who has the same mobo, I've heard that it's possible to boot off of their bios chip, take it out, put the bad one in, then flash it again to fix it.
