Bios Flash Question ASUS P6T Deluxe V2
Huserx
Hey All,
So about a week or so back I was updating my drivers etc and decided to flash the latest bios. Which I did succesfully and I backed up my current one before hand.
Now, I want to restore or rollback to my original and I cannot. Both the Asus utlity, and exflash wouldn't let me flash an older bios. So I got afudos and I finally have a working bootable USB and it still tells me the same thing.
So my question to you is, do any of you know a way to flash my bios with a bios that predates the current bios.
Thank you
redduc900
Inactive Moderator
Portland, OR
Are you running the following command to flash?...
AFUDOS /iP6T.ROM /pbnc /n
... where "P6T.ROM" is the name of the BIOS file.
H
Huserx
I ran the following command to flash?...
AFUDOS /iP6T.ROM
H
Huserx
Well, I tried and received the same error. The file is to old or incompatible.
The file was created using Asus's own bios backup utility before I flashed it.
The only difference this time is the currently installed bios was reset to defaults.
