Bios help needed
smokin_gp
Texas
I ran "Sandra" and it said that my Bios could be shadowed. How do I get to the bios? Then it said I had didabled host controllers present. Check bios settings. How do I do that? Thanks.
stool
Senior Member
Albany, NY
When you boot your system up, usually you would hit either "Delete" or F2. Do this as soon as you see the system POST, and you should get into your BIOS.
takiwa
exactly, and when you do, post a little more info on your system...maybe someone with the same board as you can help you through your BIOS...and welcome to the forums!
