Bios Settings for 4x1GBs...
phil178821
I have 4x1GB of OCZ PC26400 Platinum Rev2 modules.
My board is the Gigabyte GA-EP45-UD3R rev1.1.
Ram is running at 2.1V in 1:1 with 400Mhz FSB
I know boards are generally defaulted (and ram spds) to run two modules. Even after searching the web, I am still having trouble finding the right settings to get my 4x1GB up and running.
I have loosened my timings from 4-4-4-15 to 5-5-5-18. and my Command Rate to 2t.
I have also increased NB to 1.3V (I am not sure how much higher I could or should go).
One thing I heard in another forum is that Auto settings anywhere in the bios won't work for 4x1gb. Problem is, I not sure what to change some of them to.
my options are:
(G)MCH Freq. Latch: AUTO
the usual CAS-tRCD-tRP-tRAS
Under Advanced:
tRRD
tWTR
tWR
tRFC
tRTP
Comand Rate (CMD)
Then, still in advanced:
>>>>Channel A
Channel A timing Settings
Channel A Driving Settings
>>>>Channel B
Channel B Timing Settings
Channel B driving settings
With power control, I ahve:
MCH Core
MCH Reference
MCW/DRAM Reference
DRAM Voltage
DRAM Termination
Thanks guys.
MattNo5ss
5up3r m0d3r4t0r
I haven't tried 4 sticks in my UD3P, but I do have 4x1GB DDR2-800 XMS2 that I could try. If you haven't found an answer by the time I get off work, then I'll run those stick in my UD3P and see if I have problems.
Have you tried using 1 stick in each DIMM individually to make sure all the slots are working?
redduc900
Inactive Moderator
Portland, OR
Try changing the Static tRead Value setting for both Channel A and B to 8 or 9 (can be lowered later if need be). Keep CAS, tRCD, tRP, and tRAS at 4-4-4-12-2T w/ DRAM voltage at 2.1V, but manually change tRFC from AUTO to 54 (all other sub-timings on AUTO).
P
phil178821
yeah, I have cleared each module and each DIMM individually. From what I can see on the web, it appears gigabyte boards are a pain to get running with 4x1gb.
Thanks; I just upgraded bios and will try some more things after class.
P
phil178821
will give it a try later. where exaclty (or which on exactly) is the static read? I saw that mentioned somewhere else but couldn't figure out which on it is.
redduc900
Inactive Moderator
Portland, OR
It's located under both Channel A Timings Settings, and Channel B Timings Settings.
Code:
[b][u]GIGABYTE GA-EP45-UD3R[/u][/b]
[u][b]MB Intelligent Tweaker(M.I.T.)[/u][/b]
Robust Graphics Booster ...............:
CPU Clock Ratio ..........................:
Fine CPU Clock Ratio.....................:.
CPU Frequency ...........................: Mhz
[b][u]Clock Chip Control [/u][/b]
[b][u]Standard Clock Control[/u][/b]
CPU Host Clock Control..................: [Enabled] [Disabled]
CPU Host Frequency (Mhz) ............:Mhz
PCI Express Frequency (Mhz) .........:Mhz
C.I.A. 2......................................: Disabled
[b][u]Advanced Clock Control [Press Enter][/u][/b]
CPU Clock Drive...........................: mv
PCI Express Clock Drive.................: mv
CPU Clock Skew (ps)....................: ps
MCH Clock Skew (ps)...................: ps
[b][u]DRAM Performance Control[/u][/b][u][/u]
Performance Enhance...................: [Turbo]
Extreme Memory Profile (X.M.P.).....:
(G)MCH Frequency Latch...............: [Auto]
System Memory Multiplier ..............:
Memory Frequency (Mhz) ..............: Mhz
DRAM Timing Selectable ................: [Manual]
[b]Standard Timing Control[/b]
CAS Latency Time..............................:
tRCD .........................................:
tRP...........................................:
tRAS..........................................:
[b]Advanced Timing Control [Press Enter][/b]
tRRD...........................................:
tWTR..........................................:
tWR............................................:
tRFC...........................................:
tRTP...........................................:
Command Rate (CMD) ....................:
[b]Channel A[/b]
[b]Channel A Timings Settings [Press Enter][/b]
Static tRead Value.........................:Auto [b]<-----[/b]
tRD Phase0 Adjustmen.......................:Auto
tRD Phase1 Adjustment......................:Auto
tRD Phase2 Adjustment .....................:Auto
tRD Phase3 Adjustment......................:Auto
Trd2rd(Different Rank).....................:Auto
Twr2wr(Different Rank).....................:Auto
Twr2rd(Different Rank).....................:Auto
Trd2wr(Same/Diff Rank).....................:Auto
Dimm1 Clock Skew Control...................:Auto  ps
Dimm2 Clock Skew Control...................:Auto  ps
DDR Write Training ...........................: Enabled
[b]Channel A Driving Settings [Press Enter][/b]
Driving Strength Profile...................:[AUTO],[667Mhz],[800Mhz],[1066Mhz],[OC-1200],[OC-1333]
Data Driving Pull-Up Level.................:Auto
Cmd Driving Pull-Up Level..................:Auto
Ctrl Driving Pull-Up Level.................:Auto
Clk Driving Pull-Up Level..................:Auto
Data Driving Pull-Down Level...............:Auto
Cmd Driving Pull-Down Level................:Auto
Ctrl Driving Pull-Down Level...............:Auto
Clk Driving Pull-Down Level................:Auto
[b]Channel B[/b]
[b]Channel B Timings Settings [Press Enter][/b]
Static tRead Value.........................:Auto [b]<------[/b]
DDR Write Training .........................: Enabled
[b]Channel B Driving Settings [Press Enter][/b]
[b]{U]Motherboard Voltage Control[/b]{/U]
Voltage Type.………... Normal
[b]CPU[/b]
Load Line Calibration......................: [Enabled] [Disabled]
CPU Vcore..................................:v
CPU Termination…..... 1.200V*..............:v
CPU PLL...............1.500V*..............: v
CPU Reference.........0.755V*..............: v
[b]MCH/ICH[/b]
MCH Core..............1.100V...............: v
MCH Reference.........0.800V...............: v
MCH/DRAM Ref..........0.900V...............: v
ICH I/O...............1.550V...............: v
ICH Core............……1.100V...............: v
[B]DRAM[/B]
DRAM Voltage..........1.800V...............: v
DRAM Termination......0.900V...............: v
Channel A Reference...0.900V...............: v
Channel B Reference...0.900V...............: v
[b]{U]Advanced Settings[b]{U]
Limit CPUID Max. to 3......................: [Disabled]
No-Execute Memory Protect..................: [Disabled]
CPU Enhanced Halt (C1E)....................: [Disabled]
C2/C2E State Support.......................: [Disabled]
x C4/C4E State Support.....................: [Disabled]
CPU Thermal Monitor 2(TM2) ................: [Enabled]
CPU EIST Function..........................: [Disabled]
Virtualization Technology..................: [Disabled]
[b]Note[/b]: * refers to 45nm CPU
P
phil178821
thanks, going to give it a try now..
also, should i have the MCH voltage at? stil 1.3v? or stock?
P
phil178821
so here are the settings i currently ahve. this is with the F11 bios and the result is: constant reboot at bios post screen.
Robust Graphics Booster ...............: AUTO
CPU Clock Ratio ..........................: 8x
CPU Frequency ...........................: 3.20Ghz
Clock Chip Control
CPU Host Frequency (Mhz) ............:400 Mhz
PCI Express Frequency (Mhz) .........:AUTO
CPU Clock Drive...........................: 700mV
PCI Express Clock Drive.................: 700mV
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)...................: 0ps
Performance Enhance...................: Standard
Extreme Memory Profile (X.M.P.).....: NOT HERE
System Memory Multiplier ..............: 2.00B
Memory Frequency (Mhz) ..............: 800Mhz
CAS Latency Time..............................:4
tRCD .........................................: 4
tRP...........................................: 4
tRAS..........................................: 15
tRRD...........................................: AUTO
tWTR..........................................: AUTO
tWR............................................: AUTO
tRFC...........................................: 54
tRTP...........................................: AUTO
Command Rate (CMD) ....................: AUTO
Channel A
Static tRead Value.........................:9 <-----
DDR Write Training ...........................: Auto
Driving Strength Profile...................:Auto
Channel B
Same as Channel A
{U]Motherboard Voltage Control{/U]
CPU
Load Line Calibration......................: [Disabled]
CPU Vcore..................................:Auto v
CPU Termination…..... 1.200V*..............:Auto v
CPU PLL...............1.500V*..............:Auto v
CPU Reference.........0.755V*..............: Auto v
MCH/ICH
MCH Core..............1.100V...............: v 1.300V
MCH Reference.........0.800V...............: Auto v
MCH/DRAM Ref..........0.900V...............: Auto v
ICH I/O...............1.550V...............: Auto v
ICH Core............……1.100V...............: Auto v
DRAM
DRAM Voltage..........1.800V...............: 2.1V
DRAM Termination......0.900V...............: Auto v
Channel A Reference...0.900V...............: Auto v
Channel B Reference...0.900V...............: Auto v
{U]Advanced Settings{U]
Note: * refers to 45nm CPU
Do I have some off settings? I know I can undervolt my cpu but I just haven;t gotten around to it. I am going to try to reboot again with looser timings and the settings that are shown above ..
P
phil178821
so I tried with the above settings and looser timings (5-5-5-18) with no success.
I then tried with the above settings, looser timings, and a 1.40 MCH voltage with no success..
P
phil178821
so maybe it is the DIMM Slots. Now I do know if you a board isnt supposed to function if you are using the latter two dimms of dual channel, ie using 1 and 3 of the 0,1,2,3 dimms.
So i just took out my old sticks of ram and left in the RMA'd sticks i received today in the 1 and 3 dimms and its looking up during post.. strange..
just swapped the new RMA'd sticks from DIMM 1 and 3 to 0 and 1 and still same thing.. ODDD! let me try a cmos reset.... annd still the same.
UPDATE::
So I tried each of the new RMA'd modules individually and wouldnt u know, one of them won't post.. SERIOUSLY? A faulty RMA???
P
phil178821
Alright, so its final. I have a DOA stick from my RMA. Man, I wouldnt have thought they would have tripple checked sets they are sending out as RMA replacements...
At this rate, I should probably just wait for ram prices to recover and buy a 2x2gb kit. I have to see if they are going to pay for my shipping out since they just sent me a faulty kit..
thanks guys, i will try those tips when i have 4 working modules, lol
