FRONTPAGE BitFenix Merc Alpha Case Review
If only there was a mATX case with features like this.....Sweet case.
Solid looking case, especially for the price... If only it had a socket fan ;/
Dissapointing. Not enough room up top for a radiator, not enough room on bottom for a 3rd video card in the last PEG slot. I don't understand what they were shooting for in this case.
Its a pure budget case. Nothing more nothing less. Its not bad but you have to keep that in mind that its just such that it has functions, but high end special needs you can forget about that.
+1 to deathman20. It's a $40 case Sentential. How many $40 cases can you name that have room or consideration for a radiator and a 3rd GPU? For that matter, how many people that run tri-SLI or tri-fire are going to use a $40 case?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146061
Until I saw this thread, this was the only case under $100 I would recommend to anyone. But yea, if you're sticking tri-sli in a $40 case you have issues man! :confused:
