black borders dvd to tv out
grand106
here are some specs.graphic card mx400(detonators)1.3@1,45 celeron.Here is my problem.i am using the beta detonator 40.72(nice by the way -improved the score on 3dmark2001),and when i output the image from the pc to tv(s-video connects to tv-without been plugged the pc screen) the size doesnt fit the viseable area of my tv screen -has quite a noticeable black borders.i also had the same problem when using the detonator 28.32(the 30.82 didnt output an image to tv at all).has anyone solved this problem without the use of programs like tvtool etc(had some problems running this program and cracking it hehe).while the coding is pal b-g the detonator say ntsc and while i make it to pal and press apply the pal turns back to ntsc(anyway i can see that also when for a few sec works in pal mode the same black border appear.
helpppppppp
Check the display properties (right click mouse on desktop, then select properties, settings, advanced ) and see if there is an option to adjust the sizes of the different displays (Usually there is one for each display type you are using). I have to do that when I use the tv connector as there are no buttons to adjust the display sizing on my TV.
Al
You might also need to flash the bios of the card to get the output to work correctly if your running your card with new drivers but old bios this can cause problems
about adjusting the screen from the advanced no luck .i have tried everything.in concern of the old bios you said i might give it a try.(anyway i will change soon my card to a gfmx440 so i will check it out with the new card.thanks for answering .if anyone has an idea do send it.t
