Well I want to cool my gf3 ti200 and my athlon xp 1600 @ 1.63ghz and hopefully overclock a bit more.
I was hoping it would be good enough to cool very well when combined with a german gpu and cpu block with my eheim 1048.
german blocks here www.aqua-computer.de
they seem to perform pretty well, although no direct comparison to american blocks.
Size is a concern for me definately as I was hoping to mount it in case. I will also be using the resivour from that site also.
*edit also I would like to use low noise 120mm fans (like the 30dba panaflo's).
Probably would mount the black ice on the right side of my antec sx1040 (if your looking at the front). I would probably have 1 intake 120mm 1 exhaust 120mm then 1 120mm exhausting out the right side sucking air off the radiator.
