Blank screen after AthlonOC.com Asus A7V Tweak Guide
doma
the url to this tweak guide is here: http://www.athlonoc.com/a7v_guide.htm
I followed it 100% through. Now when I restarted my computer I get a blank black screen. The fan is working. The lights are on. I waited for 30 mins. blank black screen. I turned off JumperFree mode and used jumper mode. I set it back to default multiplier settings of 8.0 and 100CPU which equals 800 MHz Thunderbird. Is there any way to erase all of the stuff I put in the BIOS? like turn the BIOS to all defaults?
If I remember correctly there are 2 solder points next to the big Lithium battery on the motherboard that resets the CMOS. Just take something metal and connect those 2 points for a few seconds. If that doesn't work then see how it says to do it in the manual (actually I'd do that first). I hope that fixes it.
-=mac=-
if you want to clear the bios unplug your pc discharce the atx pop the battery out and put it back in this will reset every thing back to default
