- Feb 9, 2002
very simple opinion thread.
my situation is as follows atm.
I have a few questions about my cooling loop
I setup my loop mostly to lessen noise levels and I've accomplished this task I've went cold in more ways than one but never took the water plunge before this so did not know what to expect via cpu temps vs other temps.
i have a 3770k @ 4.5ghz @ 1.3v on core had issues going lower voltages maybe some degradation from going cold previously.
mobo - z77 oc formula - with the water cooled mosfets in use.
cpu is receiving water after the rez which is after the mosfets. i wanted the cpu to receive water after rads first but somehow i got it backwards i could change order if you think its necessary. to stabilize temps but ive read this is a minor factor anyways.
these parts are in play on this setup
http://www.xs-pc.com/products/radiat...-fan-radiator/
http://www.xs-pc.com/products/waterb...asa-cpu-black/
now that you have some background here my question is if my temps seem normal too you.
18*C - air
24.2*C water measured with my fluke probe
25-32 idle temps depending on cores 2 cores run warmer than the other 2 this is measured in real temp.
80-87c full load temps "core dependent" prime 1024k's measured in real temp.
temp swing is almost instant water temps mabe climb 2-3 *C over 10-15 min at same air temps.
4.5@ 1.3v
i have 1250-1350 rpmish semi high static pressure fans in play and they dropped temps fairly well they are in pull - pulling from top and back of a 280 antec case and 2 fans pushing out the front of the case. so semi positive pressure into case.
my personal thoughts are the rasa block isnt being very efficient with the transfer of heat load.
but then i hear most blocks perform similarly.
opinions?
whats your thoughts on this?
