- Jun 12, 2002
I've been reading about a lot of peoples experience with blowers lately and realised I didn't know how to compare it with an axial fan that was approx. the same size and noise level.
I checked out a bunch of manufactures spec's on various models, and noticed a trend:
Sunon Example:
(I picked fans from the same manufacturer, hoping that their potentially scewed spec's are scewed equally, so that they can be compared)
Type.....Size.........Part #....................dBA.......RPM......CFM......"H20
Axial.....120x38.....KD1212PMBX-6A.......46.5......3150.....120.......0.34
Blower...120x32.....PMB1212PLB3-A.......49.6......2100.....31.4......0.64
Both: 12V, dual bearing
Note: @ almost 50 dBA, I am not planning on running either of these at 12V! These fans just illustrate the trend I've been seeing.
Obviously, the blower fan will produce a more concentrated and easily 'ductable' airflow, simply because of the way the device operates. The axial will produce more of a 'hurricane' air flow.
There is also the HUGE difference in air flow and static pressure, with the axial's airflow a whopping 4X that of the blower, but the blower's static pressure double that of the axial.
Conclusions:
So in an open air environment (such as a case fan in a reasonably tidey case), the axial is the better choice: large hurricane airflow throws air everywhere and a much higher total airflow. Sound about right?
But what about pushing (or pulling) air through an obstruction such as a heatsink? The blowers uniform, ductable airflow has got to be better than the hurricane (with that funderwul deanzone behind the hub!!) of the axial. And does a typical large HS constrict airflow enough such that the blowers superior static pressure comes into play, and actually creates a higher air flow, in this situation? Or does the sheer air flow capacity of the axial (assuming it's ducted to the HS) still beat out the blower with HS type obstructions?
Thoughts, comments, suggestions? (other than to spend less time thinking about airflow!!
N8
Sunon Example:
Conclusions:
N8
