Blue LED on Antec 830
WaTaGuMp
Has anyone done a swap to blue LED lights on this case in particular. I am a little curious about the size of the blue LED's fitting in the stock location on this case.
The ones from frozen are 5 mm in blue, I have sent an email to Antec to ask what size they are. I will see how long it takes to hear from them, if they are like most companies it will take a while.
omg i jus did this yesterday man.......you have to buy the really tiny leds.....and no soldering or anythign they can be pulled on and off this connector thingy it looks so cool btw!
I know they are cool but I wanna know about this case only. thx
I have two antec cases and the cool thing is both size LEDs fit. the 3mm are standard and the 5mm fits. so go with the 5mm. what is the foward voltage of the 5mm. some mobos have a problem lighting 5volt LEDs.
Thank You that was the king of answer I was looking for. I also got an Email from Antec Finally saying that the 5 should work also.
