Pics will come.... lol
To start, heres the gear ->
Main Hardware ->
i7 4790k
asrock z97 extreme6
Gigabyte G1 Gaming GTX 1070
OCZ trion 150 480gb x 2
Toshiba X300 5tb
Seasonic M12ii EVO 620w
CableMods blue/black (not thrilled with these, but the amount showing wont be too horrible to use them)
PNY XLR8 1866mhz 16gb
Anidee's AI Crystal Case
Water/cooling ->
EK Supremacy CPU Waterblock
EK D5 PWM Pump/Res combo; 250mm version
Bitspower Slim 240mm (front)
Black Ice Nemesis LX 360mm (top)
Corsair SP120 pressure optimized fans for rad's x7 (push/pull for the front, push for top)
Rosewill RAWP-141411 140mm flow optimized fans for ventilation (these fans are quite awesome btw, on par with noctuas [yes])
SMC fittings, 12mm for really high flowrates
SMC tubing, UV reactive (not by design, just happens to work out that way lol)
EK-FC 1080 waterblock
Extraneous mods ->
- Trimming the psu shroud (dont need HDD cage), I want the extra room for rad + fans.
- shaving the top panel (dont need fan speed selectors, severely detracts from the aesthetics. USB connectors not required either)
- etching the front or side (haven't decided yet) tempered glass panel with leo decoration
- UV + blue LED's
- sleeving pump wires
- painting fans to match.
At this time, I'm seriously debating on getting another 1070 or not. I'd like this setup to last a really long time, and I dont really wanna be swapping out parts... like ever. Right now a 1070 is MORE than plenty for my uses, but Im not sure how long that will last at 2k. I still have to receive some parts, so I have some time to think.
Main Hardware ->
i7 4790k
asrock z97 extreme6
Toshiba X300 5tb
Water/cooling ->
Extraneous mods ->
- UV + blue LED's
