- Jun 30, 2001
Posted this over @ hardforum, but then realized you guys might know better
I got to thinking if i was going to make a bong, it would have to have a resevoir for the night, if i'm gone for a while, forget, etc.
I also realized there might be a problem finding a showerhead for a 4" pipe that doesn't take up too much of the airway for the hot air to escape the top...
If you guys could please comment on the design linked here, i'd really appreciate it.
The air in effect is forced up the tube, cooling the water along the way. My only concern is if enough air will get up the tube without much turbulence from forcing pressure inside the resevoir. While the direct air flow would not be on the falling water as in a standard bong configuration, fitting a Y connector near the bottom doesn't blow air on the water for that much time anyway.
[img="[URL]http://www.students.uiuc.edu/~kuta/bongidea.jpg[/URL]"]
Thanks a lot,
-joe
Thanks a lot,
-joe
