Booting from a CDROM on IDE 3/4
Keen
Minneapolis, MN
Has anyone else here tried it? I was able to do it several times using the WinXP CD. After it detects the CDROM drives, a message pops up that says to hit the space bar to boot off of the CD.
crazyman
San Fernando Valley,Southern California
no,I have not tried it,I assumed it could'nt be done,after reading the manual.I put my cdrom on ide 2,and my burner on 3,so I could boot from the cdrom if I needed to.maybe xp is different,I use win2k pro.But thats interesting info,thanks>
knack4it
montana
Could you please elaborate a little more? I am interested to hear how this is accomplished, as I had 4 optical drives on ide3/4 and was not able to do that, even with the xp cd. Please tell the tale.
Later.
Keen
Keen
Minneapolis, MN
I set up one drive on ide 3/4 each. I properly set up the cables and the jumpers (set both to master put them at the end of the UDMA66 cables). In the BIOS, I set the RAID/ATA & SCSI boot order option to RAID, SCSI. Set boot other device to Disabled. I have boot first device set to HDD-0. When you boot up with the disc in the drive (I had the disc on IDE 3), you'll have to press a key when it asks you to, then it'll boot up.
LiquidConfusion
Bahrain for now...
Mine is setup very similar both at master both at the end of the cable and I was able to boot from it using the esc key feature also make sure you have your bios set to be able to boot from an alternate device
\zbz\\?
Keen
Keen
Minneapolis, MN
This is how I had things set up when I recently booted off the WinXP CD.
