- Jan 4, 2001
- Northern VA
Well, after building my boss a Windows 2000 system off the Epox 8kha+ and AthlonXP 1600+, he brought it back the next day with a registry failure. Basically, after teh two initial startup screens I got the blue command line dispay saying that it could not find one of the registry data files...
So, recovery yeilded the ability to get back into windows, but things weren't quite right. Being a new system, I just reformatted the drive and reinstalled eveything.
That was about 2 weeks ago. well, much to my dismay, I learned today that its coming back to me with the same problem. No power failure this time though, and he has anew house complete with nicely grounded outlets...so I doubt this is a power issue.
Seeing as though I've used W2k on many other systems with great results, I don't feel the need to blame my installation of it. And I've setup W2k on 2 other 8kha+ systems, and never really encountered any issues.
So, once I get it back I'm gonna go ahead and start troubleshooting for a hardware problem. My first place to look will be the 300w Enhance PSU which seemed to be doing an adequate job. This system is not OC'd, and has a Speeze cooler (nice job, and pretty quiet), 2 80mm Enermax adjustable case fans, a 60gb Maxtor, 52x cd and 24x cdrw.
However, I think this has to be a power problem. One speculation I have is that poor power delivery is causing registry files to corrupt. Ofcourse, this might be becuase I first had the issue after a power failure...
The other thing that could be suspect is the HDD, and maybe the IDE cable. I'll probably swap the IDE cable out for sure, just to be sure it's working. I'm not really sure what else could cause this hardware wise...it's not oc'd like I said, so the PCI/IDE is all in spec.
Is there anything I can do in W2k to prevent this from happening again? Like I said, this only seems to happen on this system, so thats why I'm leaning towards hardware related. But, if this is OS related or a flub on my part, I need to know that so I can make a correction
Mike
Mike
