- Jul 15, 2013
ok so i recently bought a motherboard from a reputable pc parts shop that sells new and used parts heres the name of the mobo GA-G31M-S2L (rev. 1.0) the link to the mobo info is down below now here are my questions
btw i plan to install my core 2 duo E8400 that i picked up off ebay for 4$
#1 whats the best aftermarket cpu cooler i can buy that will allow me to overclock my E8400 to 4.5Ghz
#2 would i be better off putting heatsinks on the VRM to allow for a better stable overclock and if so what heat-sinks do you recommend
if possible please post links to any recommendations to the 2 above questions thanks
http://www.gigabyte.com/products/product-page.aspx?pid=2693#ov
