bought an RX 470 and realized my mobo doesnt have a UEFI BIOS how screwed am i
kaitlin4599
ok i need some questions answered as im a bit confused. ok so i recently bought a sapphire RX 470 heres the link to the model i bought
http://www.sapphiretech.com/productdetial.asp?pid=0582294D-5A90-4EF0-B5E1-5EDC1C3ACBE1&lang=eng
ok so here are my questions
#1 does this card support legacy bios because my HP Z400 desktop still uses the old bios the one that only supports keyboard
#2 does this card come with a dvi adapter i only see hdmi and display ports?
did i just buy a dud or will my pc be able to boot this card below is a link to the pc i have
http://www.tomshardware.com/reviews/...tion,2718.html
https://www.videomaker.com/article/c...ation-reviewed
will this card work even tho i dont have a uefi bios
wingman99
The motherboard has a X58 Express chipset and PCI-E slot, it should work just fine. You will need a DVI adapter.
K
kaitlin4599
but the specs for the sapphire card only state uefi they say nothing about legacy support and my mobo was released back in 2009
trents
Senior Member
As far as I know, it should make no difference whether or not you are using a UEFI interface or a traditional bios in whether or not the card works. Does the card require power supplementation directly from the PSU and if so did you connect the six pin lead from the PSU? What PCI-e standard does the motherboard support? 1, 2, or 3? The card may not be backwards compatible with PCI-e 1.0 and 2.0. Just shooting things off the top of my head here.
K
kaitlin4599
the card hasnt arrived in the mail yet im just doing research ahead of time
trents
Senior Member
Oh, sorry. I must have been thinking of another thread in my response.
wingman99
PCI E 3.0 is backwards compatible.
PCI Express 3.0 Base specification revision 3.0 was made available in November 2010, after multiple delays. In August 2007, PCI-SIG announced that PCI Express 3.0 would carry a bit rate of 8 gigatransfers per second (GT/s), and that it would be backward compatible with existing PCI Express implementations. https://en.wikipedia.org/wiki/PCI_Express
Alaric
Satan's Colon, US
A PCIe 3.0 should be backwards compatible with your board's PCIe. Other than the DVI adapter you should be good to go with the new card. Nice card, BTW
wingman99
It will be good to let us know. Do you have a six pin power adapter from the PSU for the Video card and DVI adapter? I could not see the link for your video card.
wingman99
What GTX 960 card did you have? My EVGA SSC GTX 970 had dual Bios for failed Bios overclocking and bad Bios flash.
K
kaitlin4599
IF you had a GTX 960 in the RIG, it will support the RX 470.
the 960 had a dual bios switch so you could switch between uefi and legacy
EVGA GeForce GTX 960 02G-P4-2966-KR 2GB SSC GAMING w/ACX 2.0+, Whisper Silent Cooling Graphics Card
