Breaking raid array
BenF
Hell, Michigan
Is it possible to break a two drive raid 0 array without losing the data on it? Or maybe break the array but recover the data?
psionic98
by break do you mean remove one of the 2 drives?
you should be able to remove the array and use a single drive as long as you turn off raid.. since its mirrored it should still function as a single drive
BenF
BenF
Hell, Michigan
The drives aren't mirrored, that would be raid 1. Raid 0 splits the data between the two drives increasing read and write times. I want to split the array so I can have two stand alone drives.
Ben333
Folding for Team 32!
Going to need to copy the data from the array to another drive I think.
BenF
BenF
Hell, Michigan
Thats what I was thinking too. I was just hoping there would be a software solution that would combine the split data onto unused drive space. I haven't heard of such a program but I was hoping one might exist.
gvguy39
Columbus OH
Yes, u are going to have to copy data to another drive, then disable the raid array, to then have the two raided drives as stand-alone drives.
