Today i just got my WBK38 w/ delta Fan and 80mm Panaflo fan (39.6CFM and 32db). I had planned to take out the delta fan and mount the 80mm fan on. So at the beginning, i installed the original HS and fan on the motherboard. The noise level just like an air-con machine! But the temperature is dropped from 47*C (idle by using Chome Orb) to 39*C. I was still not happy about the noise level. Thus, i began my little project to mount the 80mm fan. At 1st, i was thinking to put a grill between the fan and HS, but i find that Panaflo has no problem to mount on HS without the grill. I bent the 2 clip holders from the delta fan, and they can hold the Panaflo firmly on the HS. I was so happy and excited after it is done! it was not that hard as i thought. but it is quite difficult to install it b'cos the 80mm fan bigger than WBK38. so the clip is behind the fan. i used a flat head screw driver to push the clip down. the other hand push to the right position of the hole. eventually i got it less than 2 mins. I was desperate to start my computer.
Wow....... u cannot believe it! The noise level is so quiet!!!! My roommate also can feel the room become quiet and the different. My face with a big smile and i'm very happy with the decision i made after get some good advise from this forum!
But my happiness and success are not for long! Just less than 3 mins running!!! What happened? when i put my hand to feel the air-flow in the case, my thumb was hit by one of the Panaflo wing! My thumb is wound and the wing is broken!!! My heart is broken. I destroyed my Panaflo fan!!! Without the wing, the fan is vibrating. HS, MB and CPU are vibrating as well! The fan is not balance anymore. I 'm forced to mount the delta fan again. now my room is still noisy. i'm still listenning! What can i said? i didn't put the grill on the Panaflo, otherwise this could never happen. So put your grill on the fan now, unless you wants this happen to you.
What do i do with the broken panaflo fan? I dun know man ...... if you have good advice , please tell me what to do.
What do i learn? "Control your action when you are over happiness!"
TCS
TCS
