Broken retainer clip help ?
Dimmer
Asus CUV4x-e MOBO, PIII 933 CPU - FCPGA, I broke one of the retaining clips on the CPU riser. I can no longer use the spring to hold my Heatsink/Fan combo down. any suggestions or help would be greatly appreciated.
Thanks.
try posting in the intel motherbords section, thay might know what to do (i have never worked with any intel motherbord above a p-1 for any length of time great enough to get firmiller with it) :)
Get some industrial super glue and put a dab on the briken bit and carefully place it back. Let it dry for the instructed amount of time and you should be ok. The bonds that I make with my super glue are actually stronger than before the glue was applied in most cases. Good Luck!
