- Sep 26, 2004
My rig:
2 WD 160 GB HDs (IDE)
CPU
MOBO
Ramx2
GPU: X800 pro agp
PSU 520W
Sound Card
DVDRW
and a CDRW drive as well.
OS: Win XP Pro
And now my problem. A couple of days ago I started getting BSODs at the login screen, or within 2-3 mins of logging in. The error given is DRIVER_IRQL_NOT_LESS_OR_EQUAL ... Stop 0xD1, sometimes it list a driver sometimes it doesn't. Also sometimes the error is MACHINE_CHECK_FAILED or something to that effect, I didn't write that one down. I assumed the driver was probably a windows driver since I hadn't installed anything in the past several months, so I proceeded to boot from the windows CD and repair/reinstall windows, this was a bad idea. Now the BSOD occur during the 2nd part of the installing after it reboots for the first time, and the install cannot finish. Further investigation revealed that most of the drivers in the BSODs are from the MOBO, usb driver, HD controller, and Ethernet in order of prevalence. But, about 10% I get a windows driver listed as well, the QoS scheduler for instance. I went to this: http://www.ultimatebootcd.com/ site and downloaded a boot CD with a bunch of tools on it, and managed to add the latest BIOS update to it as well, latest being a term used loosely as its dated 2005. I did flash the BIOS, but that did not help any. Also, I have tried unplugging all PCI cards, everything but the gfx card, even getting an old HD and trying to install windows onto it, all has met with the same BSOD errors preventing me from completing the install. I have also taken out 1 stick of memory at a time and tried booting with that, still having the same errors. Currently I am running Memtest86+ from the boot CD to double check the memory, but I kinda doubt that is the problem at this point.
I downloaded the latest driver from nvidia for my mobo, but I cant install them from dos and don't know of any way to be able to without windows, which I cant use because it is stuck in mid-install. If anyone can assist with this I would greatly appreciate it.
If there is no way to repair the problem, I would like advice for upgrading. I want to keep as much of my current hardware as possible as I am on a very tight budget. I also want to get stuff good enough to last me at least a couple of yrs. As far as my computer use, I use it heavily. I play most types of games from FPS to MMOs and also use it for work doing engineering calculations/simulations as well as some light programming. I had hoped to upgrade around x-mas, when I would have more money. Right now I have 2-400$ if I switch to ramen and walking to school/work.
Any help that can be provided would be greatly appreciated, I am at my wits end, and have a project due the 31st, with all the work trapped on my malfunctioning comp I'm about to go insane.
CPU
MOBO
Ramx2
GPU: X800 pro agp
PSU 520W
Sound Card
DVDRW
OS: Win XP Pro
