BSOD , help identifying the problem?
Harlequin76
Hello,
after reducing my OC from 4.5 to 4.2 the 0x00000E bsod almost stopped totally.
but currently I have been having BAD_POOL_HEADER and IRQL blue screens and I personally have no clue with blue screens.
Anyway I downloaded bluescreenviewer to see if it would give me some info I might understand, this is what I got
http://www.overclockers.com/forums/attachment.php?attachmentid=103733&stc=1&d=1326305301
I have noticed that Kaspersky AV 2011 always fails to launch and it sends errors, maybe that is the cause of the problem?
Help will be most appreciated!
thanks!
Harlequin76
Post your complete system spec's, and boot to Memtest86+ installed to a thumb drive or DVD to check the RAM for stability. You could also run the built-in Windows Memory Diagnostic tool in Vista or Win7 if you're running either one of the OS's.
Yes, Kaspersky can cause a BSOD. I'd perform a repair install of Kaspersky in add/remove programs and run updates to see if it corrects the problem. You may also want to do a system file check (sfc /scannow) to be sure your overclock didn't corrupt important system files.
