Ive recently been having BSOD's, it started out as randomn system restarts but I then remembered the option under system in control panel to disable automatic restart and I have recorded the previous two BSOD's info.
The first -
IRQL_NOT_LESS_OR_EQUAL
Techical Info -
***Stop: 0x0000000A, 0x00520054, 0x000000002, 0x00000000, 0x8051D50C
Second -
PFN_LIST_CORRUPT
***Stop: 0x0000004E, 0x00000099, 0x00000000, 0x00000000, 0x00000000
I'm wondering whether anything can be deciphered from the information given, these two BSOD's happened just as I was quitting Halo, the second was after I manually quit it and the first after it quit with an error and said "gathering exception data", the BSOD's that I was not able to record before I disabled automatic restart happened while doing different things, web browsing, Microsoft word. I have recently bought a newer graphics card "PNY Geforce FX5700LE", but the BSOD's also occurred before I installed this card.
Several times when starting windows I have had an exclamation mark in the system tray that has had a balloon notification specifying that a file has been corrupted and to run CHKDSK, the one file I remember that was corrupt was a font file.
I don't know if these two problems are linked but I though I should include as many symptoms as possible.
The setup I'm using -
MSI K7T266 Pro2-A
AMD Athlon XP-M 2000+ (unsure whether it is mobile, CPU-Z reports it as a mobile but other factors say otherwise)
PNY Geforce FX5700 LE
CaseBuy 350W PSU
768MB DDR-RAM (mix between Samsung and Hynix PC2100/PC2300, not sure about the stability of these chips still have to run Memtest 86 to verify)
Basic Intel Network Card
Sound Blaster Live 5.1
1x40GB Maxtor HD (files)
1xSeagate 30GB HD (OS)
NEC 3550A DVD-RW
1 Front 80mm Fan intake
1 Rear 80mm Fan exhaust
HD Bay modded with 60mm fan blowing air towards rear exhaust
hope all this info helps, just making sure I was thorough with the information provided
thanks in advance
RIPSTER
The first -
Techical Info -
Second -
PFN_LIST_CORRUPT
MSI K7T266 Pro2-A
CaseBuy 350W PSU
NEC 3550A DVD-RW
thanks in advance
RIPSTER
