BSOD possibly GTX 970 problem, help :(
pauliusz02
Hi, after owning GTX 970 for 2 months, just recently start receiving BSOD after the driver update (347.52). This happens when i least expect it. No OC done to any hardware.
PC specs: 16gb ram, gtx970, i7-4790k, gigabyte GA-z97X-gaming 5, RM750 PSU.
Poblem Event Name: BlueScreen
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 2057
Additional information about the problem:
BCCode: 116
BCP1: FFFFFA805C7E94E0
BCP2: FFFFF88005E48F38
BCP3: FFFFFFFFC000009A
BCP4: 0000000000000004
OS Version: 6_1_7601
Service Pack: 1_0
Product: 256_1
Files that help describe the problem:
C:\Windows\Minidump\031415-5397-01.dmp
C:\Users\Paulius\AppData\Local\Temp\WER-12058-0.sysdata.xml
I would start with downloading the latest driver, and then completely uninstalling the current driver (even going into safe mode to delete the driver manually), and do a clean install of the latest driver.
I have tried doing clean instal of newest aswell as older drivers and nothing works. Also i ran a memtest just to make sure ram is fine.
I just got 116 error when I overclocked GTX960 too high. If you were using afterburner or other OC software with auto OC at startup then uninstall everything and then reinstall drivers.
