I have a 1ghz T-Bird AVIA chip, I can run stable at 1.33ghz @1.8v.. I can however get it to post [email protected] with no problem, until winXP starts to load and just before it gets to main screen it dumps to blue screen.. Blue screen stats if this is the first time seeing this please do the following (which lists off check disk ect..) Have I hit the max this chip will do? or is there something else I should try..
I use 147FSB x 9.5Multiplier to achieve 1.4ghz
140FSB x 10 will not post at all..
runs fine at 140 x 9.5
or 133 x 10
see sig for setup..
Thanks..
or 133 x 10
see sig for setup..
Thanks..
