Rapscallion
- Feb 15, 2022
Hello everybody,
I have been having serious problems with my pc, which is around 8-9 years old. I have had BSODs upon cold boot and in time it has become a usual thing to have while the pc was idle.
I need my windows and everything installed as they are, so a clean install of Windows or a step towards Win 10-11 is not an option.
Two days ago I took out two ram pieces out, leaving the other two (2x4GB) installed. After doing this, whether the pc was under load or idle, I had no problems for over 30 hours. However, I got another BSOD upon cold boot and a screen popped up saying "windows failed to start ...". I changed the ram sticks installed with the ones taken out. After a couple of hours I got another BSOD while the PC was idle.
I have used check disk, memory test and so on without seeing any problem. I have checked BIOS settings and nothing seems problematic. Driver update caused massive problems with the AS Media Sata controller. I had to fix booting related options with the repair mode of the Windows DVD. Thus, I am not willing to update them again.
OS is Windows 7 x64 SP1.
My PC has the following components:
Windows installed on Samsung 840 Pro 512 SSD
I7 3930K at stock speeds
Asrock X79 Extreme 6
2x4GB Corsair Low Profile CL9 1600 MHz DDR3
EVGA GTX 1080
Super flower 1200 Watt gold or platinum psu (I bought it new for 100$ about 8-9 years ago)
3 2-3TB HDD and 1TB Samsung 840 EVO SSD
I have 3 Dump files. All of them are 0x00000124. One of them was caused by ntoskrnl.exe (ntoskrnl.exe+748c0). The other two were caused by hal.dll (hal.dll+12a3b).
It looks like I have a hardware problem, but it would be great if somebody can help me by digging out the clues that might exist in the dump files. I do not know how I can upload the dump files here if it is possible at all.
EVGA GTX 1080
