budget PSU around 1200W
Pulsarius
Portugal , Setúbal.
hey , i just placed my system in a Power calculator --> http://outervision.com/b/6jWcy6 , all in stock speeds .
any sugestions\opinions on a decent budget PSU around 1200w , asking for a 1200w psu +- cause i will overclock the system CPU and GPU´s and i might get out of "juice" when i start OCing the system.
Thanks.
ATMINSIDE
Budget and 1200W PSU should never be used in the same sentence.
Go buy an EVGA G2, not something cheap, as you can kill every component in your system by buying a cheap PSU.
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
I second the EVGA G2 1200W. Its the best tier 1 'bang for your buck' PSU around really.
What motherboard do you plan on overclocking that monster with??? Only a couple will do it, FYI...
EarthDog
Buckeyes!
That is one of the rare boards that will do it. Make sure you keep that socket area cool (both front and back) when overclocking!!!
JrClocker
AKA: JrMiyagi
EVGA doesn't make a 1200 W PSU in the "G" series.
1200 W: 220-P2-1200
1300 W: 120-G2-1300
I'm currently eyeballing the 1200 P2 myself...
EarthDog
Buckeyes!
Then go 1300W. I wouldn't pay the premium for a Platinum unit unless I was actively on my PC 24/7 (as that is the only way you get your money back - think folding, mining, etc). Assuming that difference is $20+
Janus67
Benching Team Leader
I'm confused on the outervision link you posted, why a FuryX and a Fury? Why not two of the same card?
Pulsarius
Pulsarius
Portugal , Setúbal.
np ill explain.
So i have a friend in the US , and came to Portugal this month for vacations , and i asked him befor he traveled to europe to get me a R9 390X in the US (i didnt had Money for more then that) cause is that much cheaper that in europe , but he ignored me :p and bought me a XFX fury Triple dissipation , and then when he arrived to Portugal he also gave me one of his 3 Fury X´s , so thats why i have a Fury X and Fury .
Janus67
Ahh okay, well that makes sense, and that's a nice friend to have :)
bob4933
500W between the two gpus, 300 from cpu, 50 for everything else (these are conservative. And remember the fury x will downcloxk to match the fury)
1200w seems ambitious. Perhaps lower wattage will get you into a nicer psu while saving some cash.
ATMINSIDE
GPU's will pull 550W stock, much more when overclocked. I don't think 1200W is out of line.
Pulsarius
Pulsarius
Portugal , Setúbal.
ATMINSIDE
So i was looking for the PSU , i found the same model whit a diferent part number :
EVGA SuperNOVA 1300 G2 Power Supply
P/N: 120-G2-1300-XR
and
P/N: 120-G2-1300-X2
aparently the same PSU ...
and i also found this :.
http://www.xfxforce.com/en-us/products/pro-series/pro-series-1250w-psu-p1-1250-befx
the cables look horrible :p , any opinion on this PSU over the Evga´s ?
Never seen the one with an X2 on the end, not even on the EVGA website.
All the big wattage G2 units are a 10yr warranty.
The XFX is solid, the EVGA is better.
bob4933
No absolutely not. But there's zero reason to overclock them. The 9590 will severely bottleneck them in pretty much every scenario. He also mentioned "all at stock speeds".
He would be very ok on an 850w psu. Id rather see him get a good 850-1000w over a "budget" 1200w. He seems to be going the right direction though.
ATMINSIDE
He said "all in stock speeds" referring to the link on the PSU calculator.
If you read his entire first post you would also see "cause i will overclock the system CPU and GPU´s".
