- Dec 1, 2007
- Near Toronto Canada
New build coming up!
I will be building a new computer for a senior friend in my building around March 1st. I'm currently thinking of using a Pentium G3220 @ 3.0Ghz as my G3258, even at stock, is fantastic paired with an SSD for day to day use as an office, HTPC, and internet appliance, which is what this person will be using her PC for.
I plan to use my G3258 stock heatsink on her G3220 for better temps as I understand the 3258's heatsink has superior heat dissipation characteristics. I'm having trouble finding a low end board to support this CPU that has good reviews. If you wouldn't mind, please have a look on Canada Computers' website at the B85, H81, H97, H87, etc motherboards and help me pick one. I'm after reliability at the lowest possible price. I'm not looking for any particular feature set. I don't even need front panel USB 3.0. I just need a reliable board where the NIC won't crap out after 8 months and the board won't give me any problems. I was looking at the ASUS H81M-A but several poor reviews left a bad taste in my mouth. I am looking for MATX or ITX boards only as the customer does not want a large computer case.
Here is their stock browser. You can select chiset/socket/etc from the pane on the left to narrow your search
http://www.canadacomputers.com/index.php?cPath=26_1207
Also please help me pick an SSD based on the same premise of reliability and low cost from Canada Computers
Please do not select parts that are "online only" or "special order only" as we will be buying all parts from a brick and mortar location in my area. Ideally, the parts would be instock at either the Scarborough (Kennedy) or Whitby location as they are closest to us.
I'm looking to spend $50-75 Canadian on each part in question, respectively.
The rest of the system will consist of:
http://www.canadacomputers.com/product_info.php?cPath=6_113&item_id=055570
PS08 case $50
http://www.canadacomputers.com/product_info.php?cPath=33_1238_442&item_id=078134
430W EVGA PSU $51
(Suggest me an SSD)
(suggest me a mobo)
Pentium G3220
Customer's existing WD "AAKS" 500GB SATA 3gbps HDD
Customer's existing ODD
Whatever 2X4GB 1600 c9 RAM kit is cheapest when I get to the store
Customer's existing full version Win 8.1 X64
Thanks in advance, especially to EarthDog and ATMinside as you guys dominate the build help.
PS08 case $50
430W EVGA PSU $51
(Suggest me an SSD)
(suggest me a mobo)
Pentium G3220
