- Sep 1, 2019
Doesn't mounting the power supply sideways block air flow to the top of it?
where did you get the magnets for the aquareo? I have been looking everywhere
thanks
Tommy
tommycarl1, I just sent you a PM. For others wondering, I bought the magnets from a webstore in Norway: https://supermagneter.no/
They only ship to the Nordic countries; Norway, Sweden, Denmark and Finland.
Sorry to necro this old thread. But that magnet mounting is something I’d like to do in my next build (same case). You listed the site but do you have any info regarding which size screw magnet is needed for this?
Hey, I have a quick question.
From what I have read on other places, the Dynamic XL isn't supposed to have enough clearence for a thick radiator at the top slot, since the radiator + fans would go past the VRM and IO cover. But it doesn't seem like a problem for you, did you do some kind of mod or do I just have the wrong information?
I'm planning a build with the Dynamic XL, Aurous x570 pro and Black ice nemesis GTX 360. Almost the same stuff you have in terms of measurements. And watching your build tells me that shouldn't be a problem. Am I missing something?
I'd you look in the 3rd pic of post #23 you'll see the top rad is offset towards the left side of the case. This allows plenty of clearance to the mobo VRM heatsinks.
