EDIT: The new name of this build is going to be the Obsidian 800Degrees Sleeper. After the idea of modifying a car in a sexy and powerful manner but keeping it look as if it rolled off the lot like that and not and giving no hint to whats under the hood. Except in this case we have to use our imagination because the hood has a gigantic plexi glass window in it!
END EDIT:
This is my very first build log. I have built tons of computers since my first computer at the age of 12 18yrs ago. I will be making a build log for a second computer next week. It will be a Lian case with water cooling for my wife and an i7 for my wife.
The list:
Special:
Case and cooling:
Electronics:
Computer Room Audio and Video:
Living Room Audio + Video (HDMI cable goes through wall to computer)
I'm sure I am forgetting something but I will fill that in when it comes to it.
Here comes the pictures
Picture of everything that I have right now. Still waiting on the water block gtx 580 and the radiators. You can see the Martin Logan Speakers and You can see the floor standing vienna acoustics.
A close up of all the fans and little parts.
This is the T-Class chip amp. Sound quality wise they are almost on par with multiple thousand dollar A only amps and tube amps. I will be installing this inside the computer using the 12v power supply to power it and will be adding speaker terminals to the case.
END EDIT:
The list:
Special:
- 2024 T-Class digital amplifier wil be inside the case and the case will have speaker wire terminals on the back to hook up my speakers.
- Bottom 2 hard drive mounts will be gutted to make room for 240 Rad
- Autometer vehicle water temp gauge to monitor water temps (just for looks)
- Custom VRM cooling and back of motherboard cooling leads to lowered CPU temps
- I have tons of super bright LED of all colors including ultra violet will be mixing white and ultra violet LEDs in specific locations
- No spill quick disconnects with a shut off valve between them will allow me to use an external radiator in a stand with the valve closed. After disconnecting the external radiator I can open the valve and the water can continue through the loop. The other option is I will make a 4 inch hose with quick disconnects on it and when not using the external radiator I can complete the loop by connecting the tub.
- 24Bit DAC w/ headphone amplifier will try to custom mount it so its just part of the front of the case.
Case and cooling:
- Obsidian 800D
- 3x CM excaliburs on a TFC X-Changer 360 Rad
- 4x CM Blade Masters on a EK 240 Rad
- XSPC 750lph pump/res combo
- Apogee HD CPU Block
- 3 Blue Antec 120mm fans for cooling the inside of the computer
- T-Balancer bigNG fan, pump, lighting controller.
- Bracket that will hover over the top of the VRMs allowing me to put 2 40MM fans over the VRMs
- High speed 80mm fan for behind the motherboard
- Bitspower 3/8x5/8 fittings
- Autometer water temp gauge (boost gauge in picture using as a template)
- EK GTX 580 water block
- EK GTX 670 or swiftech 82 universal water block
Electronics:
- Asus P8Z68-V Gen3
- Intel i5 2500K 4.4GHz undervolted
- Vengeance 8GB Dual Channel 1866MHz Red LP
- 64GB Crucial RealSSD used for Intel Rapid Response
- 300GB Velociraptor used as main drive with Intel Rapid Response
- 1TB Samsung Spinpoint 7200
- 1TB Western Digital Green
- Asus GTX 670 DirectCUII
- EVGA GTX 580 (for physx)
- PC Power + Cooling Turbocool 1KW PSU 83% efficiency
- Bigfoot Networks Killer 2100 Ethernet card
- eSata 600 Raid Controller with port multiplier capability can run 6 drives off 2 esata connectors. I use this for my thermaltake hard drive dock.
- no dvd-rom will use use esata when needed.
- NuForce DAC w/ headphone amp
- Tripath T-Class amplifier 2024 chip
- Martin Logan Encore TF Speakers
- HP 24" 1920x1200
- Pioneer Elite Receiver
- Vienna Acoustics Floor Standing
- Vienna Acoustics center channel
- Jamo bi-pole side surround
- Jamo rear surround.
- Hitachi Director Series 42" Monitor (1 single input) has game mode to turn off any processing that would cause latency
